Device not switching on.
My device is not switching on , instead it is tripping power.
Es esta una buena pregunta?
@dinnesc make sure that your device is an LG 32CS560. If it is tripping the fuse you obviously have a short circuit on one of the board, most likely the power board. Unplug your set and remove the back. then take a good look at the power board and see if you can find some obviously damaged components. Post some images of your boards with your question so that we can see what you see. Use this guide Agregar imágenes a una pregunta existente for that.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 50
