Saltar al contenido principal
The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones. This product can be identified through it's model number, RS 120. The headset is the HDR 120, and the transmitter model number is TR 120. The Sennheiser RS 120 was released in 2004. They feature a transparent, well-balanced sound with excellent bass reproduction, making them an ideal choice for both hi-fi and TV use. The RS 120 offers freedom of movement, stylish design and optimum comfort at an affordable price.
Preguntas 44 Ver todo
Worked for years then stopped. New batteries fully charged. Reset. No
Worked for years,then stopped. New batteries charged overnight. No good. Unplugged power, sound, removed batteries 30 min. to reset. Green light is on. Still no good. Now what?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
Respuesta Más Útil
Hi,
Have you tried re-tuning the headset to listen if you can pick up the audio. The tuning wheel may have been shifted
If this doesn't work try changing the transmit channel (switch on bottom of base unit) and then re-tuning the headphones to see if it now works OK.
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Puntuación 2
Comentarios:
Good suggestion. Not successful. Slight hearing left side, BAD bass static right side.
- Por
Hi,
I know that you said that the green light is on, on the base unit but can you verify that there is actually audio available at the end of the cord coming from the audio source and not just a "loud" static or hum?
If you have another pair of 'standard' earphones plug them into the output of the audio source (if the plug is suitable that is). to prove that the audio is good leaving the source. Then if you have a speaker with the appropriate input connection plug the cord from the source into that to prove that the cord is OK.
Just trying to narrow down where the problem may be.
- Por
Good advise, I'll see if I can find an old pair of headphones to try. And/or a speaker. But again, there is some audio on the left side but it sure doesn't have much volume. Thanks
- Por
Añadir tu respuesta
Hal Norling estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 174
