Released September 22, 2017. Model A1863, A1905. Available as GSM or CDMA / 64 or 256 GB / gold, silver, and space gray.
Preguntas 85 Ver todo
Ambient light sensor noto working after repair.
After repairing several iPhone 8 lcms, I am noticing that the ambient light sensor is not working on any of them. Is the sensor tied to the original LCM in some way? If i put the original lcm back on, it works properly. If so, any replacement lcm will not work fully after repair.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
Hi, did you solve you problem? I found this article: https://www.macrumors.com/2018/04/11/iph... if it helps you.
por
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Try to scratch the paint away on the back of the screen where the sensor is supposed to look - similar to some aftermarket screens, the filter may be too thick for the sensor to see properly. If it works after removing the filter/paint, go over the area with a black sharpie. If you removed a perfect circle of the material, you can't tell a difference. I do this a few times a week.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Thank you for the response, but I am using OEM parts to verify that this is an issue. It is. No autobrightness and no true tone feature.
por
Went through every possible solution multiple screens. Multiple camera flexes and this worked like witchcraft. You sir are a genius.
por
https://www.youtube.com/watch?v=ruuP76o-...
I am encountering the same issue, the oem front flex is tied to the board but I even attempted to by pass this using reman glass to test just the LCD portion. in the video it is shown that I attach the assembly to a separate piece of glass. it functions with the OEM LCD but not the aftermarket. upon further testing I am encountering that this not only happens with aftermarket. but from oem to oem swap as well. keeping the home key and ribbon paired with its main board just swapping the LCD assembly. still results in no auto brightness function.
can not confirm but at this point I am reduced to believe they have paired something in the display itself to the motherboard
Calificación 1
Did you make sure that you have everything seated properly on the flex before putting the ear speaker and screws on (sensors seated properly in rubber mounting pieces, etc)? Also make sure that you didn't accidentally peel the light sensor off its flex because they are glued pretty well to their seating brackets. If that is the case, you will need to replace the flex which is a walk in the park.
Calificación 0
Comentarios:
Everything was seated properly and there was no damage to the flex. After replacing the original back in place, the ambient light sensor works properly. I have tried this with 7 phone so far, every time a different flex assembly is used, the ambient light sensor does not function at all. Everything else works.
por
I am just testing this issue using only OEM parts and screens.
por
Also, the proximity sensor works properly, it is just the ambient light sensor.
por
I would assume that the screen replacement would be pretty much the same to the iPhone 7, I actually haven't done an iPhone 8 yet but I have screens for them.
The only difference I see on the frame is the added two clips at the top.
por
So tell me @benjamen50 , do you ever sleep or are you a cyborg :>)?
por
Mostrar 2 comentarios más
If you replace iPhone 8, 8 plus or X screen you need to copy the firmware data of the original screen into the new screen. The needed tool is under development. I saw some working versions, what are tested and working with IOS 11.4 and 12.0 Beta. The screen data can be cloned only to OEM screens for now.
Afte the copy of the data, the light sensor works well again.
If you would like to know more about this problem read this article: http://www.futuresupplier.com/blog/solve...
You can order the box here: http://www.futuresupplier.com/iphone-8-8...
Calificación 0
Comentarios:
Link is not working. Neither is the futuresupplier.com site.
por
Thanks the notice, I checked the links and both of them are working well from my computer and from my phone.
por
ios 12 beta 3 fix the ALS but the true tone option disappears , i changed the third party screen, i use a genuine screen removed from an iphone 8 plus icloud locked, even with a genuine screen the ALS doesnt work, i upgraded again to ios 12 beta 4 but there´s no True tone option. looks like this is bug and Apple is working on it.
por
Añadir tu respuesta
Shawn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 11
Últimos 7 Días: 94
Últimos 30 Días: 304
Todo El Tiempo: 1,377
