LG 60UF850T lcd tv screen flickering
My lg 60UF850T television s screen keeps flickering. Also in the top right corner seems to be some bleeding. Can this be fixed?
Es esta una buena pregunta?
@piddo any bleeding is usually caused by a bad panel. This cannot be fixed but would require a new panel.Post some images of what your display shows. The same with the flickering. This can be caused by a bad main board, bad power board (backlight supply) a bad panel and many more things. Besides the pictures of the Panel you could also post pictures of your boards with your question. Use this guide Agregar imágenes a una pregunta existente so we can see what you see.
Fue útil esta respuesta?
Sorry mate. I’ve been super busy but here’s a short 10 sec video showing you what it’s doing. Thanks again.
This could simply be a bad Main board. I'd be looking at the boards for any obvious damage.
I couldn’t tell if anything was wrong. It all looked ok to me. Hmmmmm.
No. I sort of gave up as I had another tv I could use. Would love to fix it though.
I fixed mine , was the t-con board, I had the same problem
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 4,900
6 comentarios
I fixed mine , was the t con board, I had the same problem .
- de matias.palominos
Were you able to fix your tv? had the same problem as your tv
- de Jhayxian
- de Adam Piddington
i was able to fix mine.
- de Jhayxian
I have the same problem on the 32 inch LG
- de Simasiku Aibalelo
Mostrar 1 comentario más
