Saltar al contenido principal
Segunda generación de iPad con Wi-Fi, lanzado el 11 de marzo de 2011. Número de modelo A1395. La reparación es difícil y requerirá calor.
Preguntas 250 Ver todo
touch not working after battery replacement
Hi,
I have a iPad model A1395 with defect battery. So i replaced with new battery and tried to charge it and it works fine. But then i want to test the touch before i mount the screen back with adhesive... now touch not working and only home-button is working.
Shouldn't the screen work while it's open like iPhone screens when its not completely closed?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Hello Ibrahim Ibo, If you opened the iPad there are ribbon cables to make the touch sensitivity work i recommend that you reseat the cables inside the iPad then try again if this doesn't work clean the connection then try again.
Hope this helps
-Activoid
Update - the cable should look a little like this
Fue útil esta respuesta?
Puntuación 0
14 comentarios:
can you please show me picture of this cable?
- de
tried to disconnect the cable at both ends, still no responsive :(
- de
have you tried cleaning the gold connections on both ends such as the Logic board connections and the ribbon cable connections
- de
what can i clean with? 100% alcohol?
- de
I wouldn't pour it directly onto the board but put just a tad bit on a cotton ball and just dab it onto it that should work just fine then let it dry for around 15-30 minutes don't wipe it because then you can risk damaging the connections
- de
Mostrar 9 comentarios más
When opening the iPad did you accidentally tear the flex cable for touch glass? Inspect carefully.
If all looks good. Try slowly bending the touch glass around while touching and see if you get a response at a certain bend.
Next make sure the touch flex is properly seated in its connector on the logic board and that no pins were bent
Puntuación 0
There you go, i taked two pictures. One of the Home button component, and one of the 2-pin over the charger-component
Puntuación 0
Make sure the cables are not torn or ripped, they can rip pretty easily. If they are damaged purchase a new screen, they're relatively cheep. If they're not damage take the cables out and put them back in again. There is a white line on the cables
make sure the white line is parallel to the plastic screen connector. Also make sure the latch on the screen connector is closed.
Puntuación 0
Añadir tu respuesta
Ibrahim Ibo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 209
