My laptop won't load up after logging in
I have re-installed the latest OS and it still will not load up after I have entered the password.
Any ideas how I can get the thing to work?!?!?
Es esta una buena pregunta?
Now forgive me because I'm no Mac Genius, but I'm not sure if this would be a Hard Drive related issue or not, because you were able to reinstall Mac OS onto the computer. After entering the Password, it just hangs? Did you have a data back up prior to this incident?
Update: According to Apple Forums, this issue was noted on Yosemite and High Sierra, although the solution was to Boot into Safe Mode, and restart. What you will need to do in your case is hold the power button until it fully powers off, and then power it back on holding down the Shift key immediately after hearing the start up tone. Then when the Apple logo appears release the Shift key and Mac boots into Safe Mode. Reboot from Safe Mode and try normal boot.
Fue útil esta respuesta?
Thanks, Alec! I have been on the phone with Apple for over an hour. I've re-installed and tried to get into safe mode with Apple on the phone, it just takes forever! I thought I had everything backed up, but alas no.
They have suggested re-installing again and if that doesn't work, getting an external hard drive (a clean one) to do a back up then wipe the disk and start all over again. See how this goes, for now, thanks again for your response!
FYI, I am on High Sierra so it might be the issue.
if the update doesn't work, I'll try to reboot from safe mode the way you have suggested.
No problem, I hope that you resolve this issue soon, and I hope the info I provide can help as well. Best of luck to you!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 9,324
