Saltar al contenido principal
Repair and disassembly guides for Sony DVD players.
Preguntas 65 Ver todo
Load/Eject door will not open, cannot load DVD
Sony CD/DVD Player DVP-SR210P Load/Eject door does not open. It sounds like it is but nothing visable with the cover off is moving. What can I do to fix it?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Just fixed mine. Belt for tray eject was stretched & just slipping on the motor pulley. Dug through old bad PC CD/DVD drives & found a belt that fit. Loads & ejects tray like new now.
- de
Harbor Freight sells those general purpose O-ring variety packs, there might be one of the size needed in there?? Original drive belts are square, but any rubber O-ring of close size needed should work as long as the problem is not something mechanically jamming the tray.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
A stuck disk tray is fairly common. See https://therestartproject.org/wiki/CD_an...
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Vickie Belt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 56
Todo El Tiempo: 9,508
