Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2692 Ver todo
How can I test a replacement battery to be 100% sure it's good?
I'm about to replace a battery for a client who lives out of town. In the past, I've replaced batteries that started malfunctioning within a couple days, but since this client can't easily come back for a replacement, I want to make 100% sure the battery's good before sending them on their way.
My plan is currently to plug in a battery, turn on the device, use the Battery Life app and do a stress test with video streaming. If it passes the tests, is this enough to be sure the battery is good? Are there any other tests that can make sure this battery won't start acting up in a couple days?
Thanks.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Your testing sounds solid. However, batteries are a curious beast due to their chemical nature. The best way to insure you have good batteries is to stick with quality suppliers. If you have had issues in the past with a certain supplier, you may want to reconsider things and find one who has a very high quality rate.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Thanks for the reassurance. I'd still rather do the 2-minute test & deal with returns than spend an extra $10 per battery to avoid it. If you do the math, 2 mins x 30 x $10 = $600/hour. When I'm doing the annoying tests, I'll just remind myself that I'm getting paid $600/hour to do it.
- de
Añadir tu respuesta
fdsajky675 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 83
