Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.0GHz, 2.3GHz o 2.6GHz (Turbo Boost de hasta 3.8GHz) con 6MB de caché L3 compartida.
Preguntas 559 Ver todo
Can I replace the trackpad on a Late 2013 15" MacBook Pro Retina?
My trackpad will work for about a minute or so after startup and then stops completely. Is it possible to replace this part? I don't see any parts or instructions on iFixit. Many thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
2 Respuestas
Respuesta Más Útil
While the Both the 13" & 15" models use the same procedure Reemplazo del panel táctil del MacBook Pro 13" Pantalla de Retina finales de 2013 to gain access to the trackpad (technically a touchpad). The 13” model uses a different part MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad which won’t work in your 15” model.
You need this part: MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad.
@ajcooke01 - Replacing the full uppercase is not really needed here.
Imagen de MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad
Producto
$69.99
Imagen de MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad
Producto
$59.99
Fue útil esta respuesta?
Puntuación 5
4 comentarios:
I have found that just replacing the cable works fine. There is very little that can fail on the trackpad. MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad Cable
- de
@mayer - Very true!
- de
Please help. Macbook pro late 2013 edition trackpad = non responsive, keyboard response is delayed or non responsive. Can one replace just these 2 parts? Which other models are compatible if so. Where can I find replacement parts?
- de
@margot23 - iFixit sells the trackpad, click on the correct part above 13" or 15" depending on your exact model.
- de
I bought a new upper case for my late-2013 15" MBP. It included the keyboard but not the trackpad. I'm hoping these instructions for the 13" MBP will be all I need to transplant the trackpad to my new(er) upper case. I have a new battery to install too.
Puntuación 0
4 comentarios:
@reezekeys - Why are you replacing the uppercase?
- de
I had a few keys of my keyboard stop working. I went to Ebay to get another one but found an entire upper case with keyboard in excellent condition for $9! It had no trackpad though. I also needed a battery so I got one, and figured I’d do both jobs in one shot.
- de
@reezekeys - I would also replace the battery as well. Just follow the guide to transfer the trackpad.
- de
I needed the battery for a long time, you know how that goes! Then the tab and function keys on my keyboard stopped working.
- de
Añadir tu respuesta
gslive estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 7,435
