Saltar al contenido principal
El HP Flyer Red es un portátil creado por Hewlett Packard que se lanzó alrededor de diciembre de 2014.
Preguntas 31 Ver todo
My computer suddenly turned off and won't turn back on..
I recently bought the HP Flyer Red laptop and it has been working great for about a month until I cut the camera on and it suddenly turned off 2 days ago and won't turn back on. I tried charging it and taking the battery pack off. It came on for a split second and turned back off. I tried it again today while charging it and it came on but went to a dark gray screen with just the mouse pointer showing. What could be the problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
What do you mean by "cut the camera on"?
What OS is installed in the laptop?
Have you tried starting the laptop with the battery removed and only the charger connected?
If it starts OK allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit and then shutdown the laptop in the normal manner.
When it has completely shutdown, switch off the charger and disconnect it from the laptop
Reinsert the battery, reconnect and switch on the charger and then turn on the laptop.
If it starts OK allow it to boot all the way to the Windows desktop.
Check the battery charging status and if the battery is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
My camera turned on and now won't turn off
- de
Hi @Shania Bacchu,
Not quite sure what you mean.
Are you asking about the webcam in your HP Flyer Red PC?
If so what is the exact problem?
What program are you using the camera with etc?
- de
Añadir tu respuesta
krcayson1982 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,389
