Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 865 Ver todo
What is iPhone 7 plus Black Screen with horizontal (---------) line?
2 Months ago my screen broked by a crash from a corner of the phone. after that i changed the screen and it start having rapidly restarts in each 5-15 minutes with showing first black screen with horizontal ( -------------------) line. does any body know what is the problem ? cuz phone is useless and not working any more ?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
Solución Elegida
The first thing to do is determine if the replacement screen is defective. If you still have the original, cracked screen, you could connect (Follow this guide) that one to see if it also has the same symptoms. If it does, then you likely have an issue on the logic board and that would require a micro-soldering repair.
If the original screen works fine, then you should contact your screen vendor for a replacement.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
Minho thanks for your answer. after changing back to original one still there is the same problem so for micro-soldering repair can please a bit explain me here about what exactly might be the cause or what must be change or repair on logic board
thanks a lot
by
Is this with front camera unplugged too?
by
Can you post a picture of the screen and artifact?
by
Añadir tu respuesta
ali karimi estará eternamente agradecido.
Ver Estadísticas:
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
Todo El Tiempo: 1,192
