Saltar al contenido principal
A1418 / EMC 3069 / 2017 / Procesador i5 de cuatro núcleos a 3.0 GHz, 3.4 GHz o i7 a 3.6 GHz de cuatro núcleos. Lanzado el 8 de junio de 2017.
Preguntas 175 Ver todo
Upgrading the RAM from 8 to 16 GB
Hi.
I've decided to upgrade my RAM from 8 to 16. I have iMac 21.5, 4k 2017. pro 555.
I saw on Apple's official site, that I can upgrade my system to only 16 GB maximum.
Can I put in two 16 GB modules into this model?
On this site I found that I can buy 16 GB RAM. But, this Mac has 2 slots for RAM. Should I fill both slots (do I need two 8 GB modules?) Or, I can put only one 16 GB module in and it will be enough?
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Can you please verify which is your exact model. Is it this one iMac 21.5" 2.3 GHz i5 (Mid-2017) or is it one of these iMac 21.5 3.0 GHz i5 (4K, Mid-2017) iMac 21.5" 3.4 GHz i5 (4K, Mid-2017) or iMac 21.5" 3.6 GHz i7 (4K, Mid-2017)
As you can see in the links the first can support only unto 16 GB of RAM and the other three can support up to 32 GB of RAM!
- de
my is 3.0 GHz. with Radeon Pro 555
- de
as I understand, My RAM could be 16 gb max. But how many I should install? 2x8 or 1x16(can i do this?)
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Standard RAM: 8 GB Maximum RAM: 32 GB*
RAM Type: PC4-19200 DDR4* Min. RAM Speed: 2400 MHz
Details: *8 GB of RAM is standard and reported as onboard with an optional upgrade to 16 GB of RAM at the time of purchase for an extra US$200. However, in a pleasant surprise, this memory actually is not onboard and can be replaced or upgraded after the initial purchase of the Mac, it's just unnecessarily complicated. This model can "unofficially" support 32 GB of RAM.
Here's how to install it:
Reemplazo de RAM del iMac Intel 21.5" Retina 4K Display (2017)
Fue útil esta respuesta?
Puntuación 3
5 comentarios:
I decided to give my Mac 16gb RAM. Can I Buy 1x16 Ram, or I should fiil all 2 slots?(2x8)
- de
or 16(new)+8(old), mb somebody tell, that it’s bad for Mac, because different memory(
- de
I'd replace one of the 4GB sticks with a 16 GB and leave the other 4GB in it.
- de
Is it bad for system? When RAM different
- de
No, you lose interleaving but the increase in RAM more than compensates for that small drawback.
- de
Añadir tu respuesta
Dmitry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,230
