Rear Brake light is out and its not the bulb.
Rear Brake light out and both brake a front blinkers work on and off with the light flickering fast when it does work. Help
Es esta una buena pregunta?
OhhhK. When your indicators flash fast, usually that means that one has blown or has a fault. Or it could be your indicator relay.
If the rear brake light is out and it isn't the bulb, then it can only either be a fuse, relay or wiring. I'd check your fuses first.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 95
