Saltar al contenido principal
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Preguntas 494 Ver todo
Internal display doesn't work on Windows, only Mac.
So this is a bit of a weird one,
I have a Macbook Pro Retina Mid-2014, The Internal LCD of the laptop only displays when it's running Mac.
It will boot up fine into Mac and works 100%, but when i boot into Windows all i have is a black screen unless i plug in an external monitor. (The internal screen stays black and undetected by windows)
I believe it could be a driver or software issue, how would i go about putting that to the test?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Have you run the Bootcamp wizard in OS X and created a USB stick with Windows drivers on it? If you haven't create one, then boot into Windows with the monitor attached, and then install all the drivers.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
James Final estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 53
