Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2305 Ver todo
iPhone Not Turning On After Using Cheap Wall Charger
I had a fully functioning iPhone 6s until a few days ago. Will traveling with my family, my dad brought a wall charger that we later found to be faulty after my phone died. The minute I plugged the charger into the outlet to charge my phone, it first froze and then died.
I have tried multiple steps to try to bring the iPhone back to life. I would do a hard reset, but that wouldn't work. Honestly, my iPhone has no signs of life thanks to the faulty wall charger. What can I do to fix this problem? Is the logic board officially fried and therefore unusable?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
2 Respuestas
Respuesta Más Útil
Could be one of many things or could be a combination of them:
- Charging port and battery blown (You would need to replace both at the same time to get the phone to work properly)
- Battery gone bad from faulty wall charger (Battery just needs to be replaced if that's the only part faulty)
- Charging chip, power management chip gone bad (Tristar, board-level / microsoldering repair)
- Main processing chip gone bad, if this is the case the phone is basically paperweight.
- One or more capacitors near the main processor chip shorted (in this case they usually get removed and if needed replaced as well).
Fue útil esta respuesta?
Puntuación 1
Ben I'd say you've gone a little too far :)
Using a non-original charger causes a malfunction in the motherboard that is connected to the U2 component.
Throw away the charger, go to a professional lab to replace the component.
Use only original charger % cable! also in the car(greffen approved by apple - car charger very good!)
Puntuación 0
Añadir tu respuesta
Makhwarand Khan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 134
