Saltar al contenido principal
Guías para la versión LTE del iPad Mini 2. Anunciado el 22 de octubre y lanzado el 12 de noviembre de 2013. El iPad mini 2, originalmente conocido como iPad mini con Retina Display, tiene todos los píxeles del iPad Air en una forma más pequeña de 7.9 " factor.
Preguntas 61 Ver todo
Is this a battery leak?
I opened an iPad Mini earlier to replace the screen and found a shiny coating on one end of the battery. Does this look like a battery leak?
The coating is already dry and feels fairly smooth. It only appears along the top of the battery along the edge that's exposed under the LCD shield plate. There's no sign of fluid below the battery or elsewhere in the iPad. This device has been repaired before.
If it's not from the battery, is there anything else in there that might leak? The LCD looks fine. There were no reported battery issues, either.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
That does not look right.. Looks like something melted at the bottom of the battery.
Fue útil esta respuesta?
Puntuación 0
Yes, you will probably have to replace the battery and any components that have been damaged by the leakage.
It looks at though the battery acid has dried up.
Puntuación 0
Añadir tu respuesta
Ket estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 835
