Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Xterra se introdujo en América del Norte en el año modelo 2000 (año calendario 1999) y se comercializó utilizando el lema Todo lo que necesita, nada que no necesite.
I think I busted my timing belt
I have a supercharged Nissan xterra, it was really low on gas so i drove to get it gas, but it wouldn't go over 20mph unless i put it in supercharge got gas it was fine driving out of the gas station but then it would only go to 20 again i got it to 45 almost turning onto the freeway and it turned off in the middle of driving it i made a u-turn and the power streeing went out thats how i know it shut down, it wont start up now, it will act as if it is going to turn on but never really starts up? now when i check the reader it says camshaft or crank shaft sensor (not sure witch one), but it didn't have the code there before this happened.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Check the distributer. I was traveling down the highway, and it was running rough, so I slowed down and ended up going 20, before having to just finally pull over. The bearing had gone out in the distributer. I bought a new one for about 200, installed it, and it runs great now, 30,000 miles later. I'm at 230,000 now.
2001 Nissan Xterra XE
Fue útil esta respuesta?
Puntuación 0
Ditto on the distributor. Mine went out as well and the car was really struggling. Took the old one out, and just like @ifoster, a bearing seems to have gone out. Replaced with the distributor assembly from my parts car and now it’s driving great again!
Edit: I have a 2000 XTerra.
Puntuación 0
Añadir tu respuesta
morganh769 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 535
