Saltar al contenido principal
Lanzada en USA y Europa el 28 de Julio de 2017, la Nintendo 2DS XL es una consola portátil de la familia de la 3DS XL.
Preguntas 72 Ver todo
Are the face buttons the same size as other 3ds models?
I was thinking of replacing the face buttons with pink rather than orange, and then making a custom top shell. Can't really find any 2ds-specific buttons, so I was wondering if they're the same size as other 3ds models. I figure that they are, but it's best to check. Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Hi
No they are different unfortunately, the little notches on the edges of the buttons which ensure they are seated in the right hole on the housing and the right way up are different.
Not sure about the rest of the profile such as the height and diameter of the button (they look very similar if not the same). You might be able to mod a set of 3DS XL buttons to fit by cutting new notches on the side so they fit the 2DS XL housing.
The notches are not visible from the outside so cosmetically if you can mod them to fit the holes in the housing they should look perfect once fitted.
Kieran
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Teeth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 49
Todo El Tiempo: 1,626
