Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Guías de reparación y soporte para el Galaxy E7, un teléfono inteligente Android lanzado por Samsung a principios de 2015. Cuenta con una pantalla Super AMOLED 720 x 1280 de 5.5", una CPU Snapdragon 410 de cuatro núcleos a 1.2 GHz y 2 GB de RAM.
Preguntas 28 Ver todo
Why won't my phone turn on?
I turned off my phone at 66% because my class had started. After class I wanted to check my phone but it wouldn't turn on. I took out the battery and pressed the power button to "drain the phone" but that didn't work. I then charged for about 10 min. and it still will not turn on. What is the problem?
Update:
I think the phone is on, but the screen won't work. If I get a phone call are a text message my phone will alert me, but I can't turn on the screen.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Aubriel Jensen possibly a failed display. you want to first charge it longer than 10min. If you have no results after having let it properly charge, I suggest you try a hard reset but do not reset it
Turn off your phone completely. (Press the power button for few seconds and tab on Power Off)
Press and Hold Home + Volume Up + Power keys together at the same time about 10 seconds.
As soon as you get into the Android system recovery mode, go to wipe data/factory reset using the volume down button and select it with the power button.
When asked to confirm “Confirm wipe of all user data?”. Select NO
Select reboot system now.
If your phone did not show anything on when you tried to reset, consider replacing the display.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
it worked...thanks
- de
Try TESTING a different charger. If it works with a different charger, then you need a new charger.
Or Go to a service center and replace the charging panel
Puntuación 0
Comentarios:
I tried it.... It didn't work
- de
did not work
- de
Añadir tu respuesta
Aubriel Jensen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 1,783
