También conocido como Samsung Galaxy J1 Duos, con dos ranuras para tarjeta SIM. Anunciado en enero de 2015.
Preguntas 98 Ver todo
Will not turn on, Just vibrates when on charge and has new battery
Hey guys i have a samsung j1 i left it at home one night and when i came home it was flat i tried to turn it on it didnt turn on so i put it on charge and it just vibrates every 5-10 seconds continuously and i have replaced the battery and it still just vibrates on charge and whrn you try turn it on it vibrates to let you know it has switched on but then nothing happens and i need pictures and data off the phone
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
@telfz0r Is it still being recognized by your computer when plugged in? this sounds like a display issue since that is what could make it vibrate.
por
Agregar un comentario
2 Respuestas
Option one: Try a new charger.
Option 2: Go to a service center and replace the charging panel
Fue útil esta respuesta?
Calificación 0
Comentarios:
Sometimes when a charger is in the same position for a while, this happens. It will only charge in a specific position, which explains the continuous vibration. It is simply charging in one position, then not charging when you move it even slightly. You need a new charger.
por
No its not the charger I have tried 5-10 different combinations of power connections and USB cords
por
Mmm...I'll keep that in mind.
por
HEY i have the exact same problem no visuals on the screen just the rythmic buzz every 5 seconds letting you know that your lifes a failure and nothing will ever be right again. If you solve this problem please let me know :)
Calificación 0
Añadir tu respuesta
Jake Walters estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 8
Últimos 7 Días: 51
Últimos 30 Días: 247
Todo El Tiempo: 1,430
