Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Preguntas 575 Ver todo
Screen goes dark during phone calls after replacement. Help!
iPhone 6s plus, I replace a cracked screen by purchasing the aftermarket kit from ifixit. The repair went without a hitch since I was following the disassembly guide. The replacement screen displays the correct colors and is perfect.
However, during calls, the screen goes dark as if the sensor on the very top of the screen is being blocked. Did I do something wrong or is my replacement unit the issue?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
You may have damaged or incorrectly installed the Front Camera/Sensor flex, which contains the proximity sensor. You should go back through this guide to double check your work.
Fue útil esta respuesta?
Calificación 3
Have either of you installed a screen protector or left the plastic protection on that came with the new screen? If so try removing it.
Calificación 0
Comentarios:
There is no screen protector on it and t he plastic protection has been removed.
por
Añadir tu respuesta
Riannon Webb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 57
