Saltar al contenido principal
El Samsung Galaxy Note 5 (llamado Note5) es un teléfono de estilo phablet, fabricado por Samsung, lanzado en agosto de 2015.
Preguntas 269 Ver todo
wont turn on or charge after dropped
My phone wont turn on anymore. I already did the hold home volume up and power button. Still doesnt turn on. Try to charge it but the phone still doesnt turn on and it keeps overheat when i left it charge it.. Then i try to investigate i removed the back cover of the phone then i saw my battery's connector to the motherboard is cut off. Kindly see the image link below. My question is it possible to fix this or do i need to buy a new battery? I think this is the one cause of the problem not 100% sure
https://imgur.com/a/8fWpk image 1
https://imgur.com/a/aAKxR image 2
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi!
It's almost impossible to re-solder the battery ribbon connector, unless you have very good micro-soldering skills and are willing to put up with the risk of causing a fire while working with the hot soldering iron near the battery. Try replacing the battery, as you said, that should be a good place to start from.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Okay thank you. Later ill buy a new battery and check if the issue still persist
- de
and one more thing. after i remove the back cover. There is a white thing like stickers on both sides. and i just cut them off. is this important on the phone? should i buy a new cover too? sorry not really familiar with this. so that i im not going back and forth.
https://imgur.com/a/HKsyG
- de
Hi!
If the white things you cut trough are sticky to the touch they may need to be replaced, other than that no. I can't remember if the Galaxy Note5 was waterproof or not, but after this repair it won't be any more. Just keep that in mind.
- de
Añadir tu respuesta
Jomai Masangkay estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 2,715
