ne s'allume pas du tout
does not come on at all after flash recovery .
Es esta una buena pregunta?
Any lights or vibrations ? Try removing the battery then holding the power button for a few minutes then reinstalling battery and powering it on . If this brings no joy then try getting into the recovery menu. This shows how to do this
https://www.youtube.com/watch?v=q23KvYy-...
You may want to just do a cache partition wipe first instead of the factory reset . You may just need a fresh boot . If that doesnt work then go with the factory reset but understand when you do it will wipe the phone clean and you will lose your data. Hope this helps
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 40
