The console refuse to read a disc
My PS2 has been used for 7 years and recently it doesn't read any disc but the browser said "Reading disc...".After a few minutes it said "Disc read error".Any solutions?
Es esta una buena pregunta?
I am assuming that you are out of warranty since your console has been used for 7 years :-) Of course you may just have a dirty laser that needs to be cleaning and most recommend isopropyl alcohol or just a good optical lens cleaning cloth, available in most department stores with their spectacles. The other issue could of course be mechanical in nature that need a little bit more effort. There is a great guide right here it is also possible that you will require a new laser assmbly if your laser should not be working at all. Sustitución del conjunto del láser de la unidad de disco óptica has that. There are also decent instruction in how to deal with your read error drive right here and some more here. Good Luck to you and see if it works for you.
Guía
Dificultad:
Fácil
15 - 40 minutes
Guía
Dificultad:
Moderado
20 minutes
Fue útil esta respuesta?
welli have a Ps2 slim and its reading some discs but some not what to do???
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,260
5 comentarios
I've tried to clean the lens.But it is not working.
- de Honam1021
My device model is SCPH-30006
- de Honam1021
Have you checked on the links that talk about the adjustment? I believe its the last one I posted in my answer.
- de oldturkey03
I checked the links,but they doesn't work for me.
- de Honam1021
If even after adjustments and cleaning and after making sure that your dives cables are all connected appropriately I think you may just be due for a new drive :( sorry
- de oldturkey03
