El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3639 Ver todo
iPhone 5s won't turn on
Hi! I have an iPhone 5s fallen in water. He was in bootloop so I tested the battery and it was dead. I changed the battery and the bootloop continued. So I remove the EMI shield and there aren't water damage but now the phone won't turn on. Initially it warming around the Power IC and all the capacitors around it were short-circuited. I heated up the Power IC and now the capacitors are ok but the phone won't turn on. I leaved in the battery all night long and it has fallen from 3.80V to 3.16V. Please, can you help me?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
I had a similar issue with an SE, got wet, wouldn't accept a charge, was bootlooping... new fully charged battery didn't fix it - replaced the charging port board and everything worked after that. If you don't have another 5s to swap parts with, I suggest trying a new charging port board.
Fue útil esta respuesta?
Calificación 0
I fixed a iphone 6 that was water damaged by replacing the battery, and when it still wouldnt turn on, I replaced the screen and it worked like new, maybe try replacing the screen?
Calificación 0
Añadir tu respuesta
Eliseo Di Iorio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 40
Todo El Tiempo: 647
