Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.0GHz, 2.3GHz o 2.6GHz (Turbo Boost de hasta 3.8GHz) con 6MB de caché L3 compartida.
Preguntas 580 Ver todo
Screen problem after battery replacement
I'm currently using Macbook Pro Retina 15" Late 2013.
I just replaced the battery that I ordered from this site. Followed every step in the tutorial. When I turn the laptop on, the screen acts weird as you can see from this link.
https://youtu.be/9ANT4xCj87A
Everything else such as keyboard, speaker, trackpad is working fine.
How to fix this ?
Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
I have a 13" Late 2013 MacBook Pro that seems to be starting to do this same thing. I did replace the battery a few months ago.
- de
Agregar un comentario
1 Respuesta
Are you sure its the 2013 model and not 2012? the 2012 had an issue with the gpu vcore chip and poor solder joints, the solution is to go around the edge with alot of no clean flux and a really good fine tip soldering iron and resolder each joint.
Apple used a pathetic piece of shoe rubber between the bottom casing and the board to hold it in place as a ‘fix’ in there repair centres and its well documented that fails in time, apple never revised the board so its likely to have caused issues just removing the bottom case and disturbing that chip.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Thanyaboon Tovorapan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 167
