My tv went black but has sound what’s wrong
I was watching tv and my tv went
Black I can still hear my cable playing
Es esta una buena pregunta?
@egormxo verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a station where you can hear the sound See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Agregar imágenes a una pregunta existente for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Fue útil esta respuesta?
I did the pull out the plug and hold the mute button..it worked. Thank you
What f it’s a backlight problem how do you fix that
I fixed it by unplugging everything. Thanks- forever grateful
If it's a backlight problem how do I fix it
Its a backlight problem how to fix it
Ultimas 24 horas: 50
Ultimos 7 días: 333
Ultimos 30 días: 1,475
Todo El Tiempo: 368,260
36 comentarios
How is your TV hooked up? HDMI or AV?
- de Aiden
i am hooked up hdmi. i turned all lights off and the tv is black as night. audio still works... and after the picture went out there were a few crackling noises... 42".... vizio purchased in 2014. a not so delightful fun sponge. :(
- de lisa
Hi @iambeautybird ,
With the TV turned On, did you try shining a torch at an angle close to the screen to see if an image was there or not? You didn't specify.
Just turning off the lights is not good enough to detect an image.
This will help a bit with the diagnosis, as if an image is detected then you have a backlight problem whereas if there is nothing at all then it is more likely a power problem or mainboard problem.
See the Chosen Solution below on what to do regarding further checks by you.
- de jayeff
My tv went black but still have sound and everything that said so what I do next
- de tyreshiajones323
my screen goes black (sound stays on) at unpredictable times and I can play with it (on and off and back and forth to Smart TV function) and it comes back on. Then I sit back and wait for the next black out-can be minutes, hours or days. And I’m hooked up to Direct TV. They checked out the cable hook up and said it was fine. My feed also comes through a home entertainment system.
- de terrelldahlman
Mostrar 31 comentarios más
