Computer Tries to Boot but keeps shutting down.
Hello! I had acquired as of recently a new 3440x1440 monitor from massdrop which I had been troubleshooting for the past 2 days to see why it wasn't connecting to my laptop which is an ASUS G751JY-DH71. I have had the laptop for about...I think 3-ish years at this point. It has a 980m graphics card 250GB SSD, and 1 TB hard drive.
Well I got the monitor to work after I changed the hdmi cable, it was running just fine while I was tweaking with some settings and then suddenly turned off. I unplugged everything and tried turning the laptop back on and sometimes it get past automatic repair and shut off or shut off as soon as I turn it on.
Now this is the second time this has happened in a span of 3 months, the first time it did it we took it up to a local repair place. Which I figured it was just the laptop finally beginning to overheat, I was correct and we got the laptop apparently professionally cleaned and working again. SSD and Harddrive were both in good health. Now this is the second time, I followed a tear down of a similar laptop on the site, took it completely apart and at least tried to remove some of the dust with a can of compressed air. Which it looked quite dirty despite apparently it was being cleaned. I'm pretty sure it's not my SSD or Harddrive since we got those checked when it initially happened as well, not a single problem. Is there any tips possibly someone has on cleaning? Does it sound like the overheating issue again? Or like a component failure? When I cleaned it with a can of compressed air it nearly restarted all the way and even made it past system repair before shutting off, now its struggling to get past that.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
This has happened before with my laptop and it was a battery issue. After I got a new battery it worked fine. Maybe getting a new battery will fix your issue.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Its actually my power brick but im thinking a battery replacement will be necessary as well, i'm planning on doing another take apart to do a full clean in the future after i get some more tools so I'll replace it then! For now, new power brick! Thanks for the help
por
No problem.
por
Añadir tu respuesta
Skylar Shackelford estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 26
Últimos 30 Días: 183
Todo El Tiempo: 1,200
