Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 1933 Ver todo
Charge port - can I replace my iPhone 6s CP with the one in my iPhone6
My iPhones keep losing its ability to charge (3rd in a few years). It usually begins with some lint getting in the charge port, then it'll be okay for a little bit. Then it will act up again, but with no link in the way. I've found that 90% rubbing alcohol with a tooth brush will usually fix this situation. And the last legs are when the phone will only charge in very percarious positions. This whole process is very frustrating, I'm currently in the 3rd stage of my phone ailment where I'm only able to charge my phone in a diagonally upside down position...
I bought a charge port for my iPhone 6 a few months ago - but the phone itself became so slow and the battery was so poor that I ended up getting an iPhone 6s. The new iPhone 6s was working great until recently - I'm not doing the awkwardly placed charging work around.
I was wondering if I could remove the newer charge port from my iPhone 6 and put it into my declining iPhone 6s.... would they be compatable?
Thank you ,
Patrick
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
What about a IPhone 6s Plus and a IPhone 8 Plus charging ports. Can they be swapped out?
por
Agregar un comentario
Kits de Reparación de Batería de iPhone
Sólo $29.99
Buy Now
Sólo $29.99
Buy Now
1 Respuesta
Solución Elegida
They will not work on eachother. For one the speaker on 6s has different "connector pads" than the iphone 6
Fue útil esta respuesta?
Calificación 1
Comentarios:
Thank you, I appreciate you response. I checked out the replacement peaces, too and realized they're different. Thanks again.
- Pat
por
Añadir tu respuesta
Patrick McKenna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 12
Últimos 7 Días: 94
Últimos 30 Días: 406
Todo El Tiempo: 4,565
