Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Preguntas 572 Ver todo
iPhone 6s+ touch lag on battery, but not when charging after screen an
I replaced a screen and battery on a 6s+. The customer brought it back afterwards because he said it was laggy. I did a factory reset on it but that didn't work. So I tested the phone with a couple other new screens but that didn't fix it. I also tried a couple new batteries but that didn't fix it. I noticed it was fine when charging but not when unplugged. Any thoughts on what might cause this?
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
As a shop owner, I'll safely assume that you can vouch for the good working condition of the replacement parts you tried. In that case, it's hard to say what could be causing the problem. Did the customer give you any background history of the device?
Considering all of the issues with the iPhone 6S, aftermarket screens and iOS 11 (you can read more on that here) as well as the throttling issues Apple has admitted to (you can read on that here), it sounds like it could be a lot of things. Make sure the phone is up to date, try some known-good parts (again) and see. If that doesn't solve it, then I suspect there may be a deeper issue, perhaps on the logic board.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Nick Stone estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 20
Últimos 30 Días: 93
Todo El Tiempo: 680
