Saltar al contenido principal
Identified by model number G6U46UA.
Preguntas 2 Ver todo
Touchpad Pointer prematurely executes when it "hoovers" over something
When using the touchpad, and moving the pointer around, if it moves across an executable item, even "hovering" over it for a split second, it executes that command before you "click" on the touchpad left button as you would expect to do.
This is horrible, and I can't imagine that this is the way it's intended to work. Is this something that can be fixed with a setting change, driver change, or otherwise?
Es esta una buena pregunta?
Puntuación 0
1 comentario
What Operating system are you using?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Looks like I've found a "fix"; in "settings", touchpad, turn off the "finger tapping" option -- this seems to have worked ok.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Byrne Whitehead estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 71
