Saltar al contenido principal
El iMac G5, impulsado por el procesador PowerPC G5, fue lanzado originalmente en el 2004.
Preguntas 453 Ver todo
How to remove the gray silicon rubber adhesive
I got in the capacitor kits, opened up a couple of different iMac G5 power supplies only to find them packed with gray silicon rubber adhesive. No wonder these things overheated. The question is: is there some easier way of getting this crude out other than cutting, picking and pulling?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
The only stuff that I know of is Acetone. Of course not sure how the electronic components and the PCB will hold out to that. 3M makes a product that the boaters down here use. It's a citrus based adhesive remover and they say it takes of the silicon adhesive used in boating. It's a sticky situation with the components but worth a try. Good Luck.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
+ It's called ":goo gone", I'll give it a try and let you know
- de
Thank you for accepting my answer and I hope you get the goo gone quickly.
- de
You could pick a small piece off and test alcohol and other safe solvents on it. You would be looking for a reaction that would allow you to peel the stuff off. Of course ideally it would dissolve. Good luck with it and plus for the question--never an easy answer.
Puntuación 2
1 comentario:
+ for that. Isn't it cruel to waste the alcohol.
- de
Añadir tu respuesta
mayer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 764
