Saltar al contenido principal
Guías de reparación y soporte para unidades flash USB, también conocidas como unidades de salto, memorias USB o memorias USB.
Preguntas 46 Ver todo
Repair USB Flash Drive
I broke the connector off my USB Flash Drive and would like to repair to recover the photos on the drive. How do I solder and repair?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I have gone on YouTube and found several sites that will help, but none of them can tell me how to make sure I have the wires going to the right place. any thoughts?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @bcwright3 ,
There are plenty of videos on You Tube which describe various options on how to connect to the flashdrive to access the data.
The link above is just used to show you. Check out the list of videos down the right side of the page in the link and find the one that best relates to your problem and that you are comfortable with to do the repair.
Update (02/26/2018)
Hi @bcwright3 ,
If the USB connector was connected directly onto the pcb the by rights it should be a straight connection as shown in the image below.
Worst case would be if your put the power (+5V VCC) on the wrong connection as this would damage components.
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Brian Wright estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 121
