Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Why is the wifi and the bluetooth signal weak?
Hi!
I am the only one in the house with this problem - When I go to my room, the wifi-signal on my iPhone disappears. I only have wifi-signal if I am in the room, where the router actually is. If I bring another iPhone or iPad to the room, they still have a good wifi-signal. And no, it has not always been like this. It started like 2 months ago.
I have another problem - the bluetooth-signal is bad as well..
What to do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
5 comentarios
Replace the wifi/gps antenna and you are good to go.
- de
I have the same problem too, the wifi router is in the living room but when i go even in the kitchen the wifi signal disappears from my iphone much more when i go upstairs. Do u know how to fix this?
- de
I have a question: When this started happening for you, did you drop your phone, or did anything hit it? This also applies to anyone else reading this with the same problem. I have this problem, and my phone fell off my bed and then it started to stuff up. The night before, I was having a bit of problems with my Bluetooth headphones, but my Bluetooth signal tends to go weak every so often, I thought it was normal. That night, I was able to connect to the wifi from my room, but after my phone dropped, I have to basically put my phone to my headphones for them to connect (other devices are fine), and I have to be standing no more than four metres from the wifi router for my phone to connect.
- de
well my phone was a litte in the wate r but I thought this was no problem because it kept working. Should I get a new phone or fix this one? I have a 6s
- de
My phone dropped and my screen broken and ever since then I’ve been having issues on the Bluetooth and WiFi signal
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
You need to replace the logic board antenna..
Part:
iPhone 6 Logic Board Antenna Flex Cable
Imagen de iPhone 6 Logic Board Antenna Flex Cable
Producto
$9.99
Fue útil esta respuesta?
Puntuación 1
Below are the three WiFi signal adapters. Usually bluetooth isnt effected by anything but the board connector, however, your wifi signal could be caused by multiple antennas.
https://www.etradesupply.com/apple-iphon...
If you replace these three antennas, and your issue is still not fixed, then you are looking at a Radio IC Failure. The IC used to process the WiFi, and the Blutooth both go through the same Chip on the board. in which case, you can replace the Logic Board, or take yours to someone with experience in SMT to fix the board you have.
Puntuación 1
2 comentarios:
That is very true indeed.. From my experience tho.. GPS/Wifi and bluetooth acting up.. change the logic board antenna..
60 out of 67 phones in my shop has been fixed by replacing the logic board antenna.
- de
im in no way trying to say your answer is wrong. i was only trying to broaden the answer to encompass the other 7 phones as a possibility.
- de
Replacing the F Antenna fixed my problem... iphone 6!!! https://m.youtube.com/watch?v=iqbZRwuvUb...
Puntuación 0
Añadir tu respuesta
Denis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 35,134
