Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Apple AirPods son auriculares inalámbricos lanzados en diciembre de 2016.
Charging Airpods without the charging case.
Hi,
Ive lost the charging case for my airpods, is there an alternative way i can charge the airpods?
Maybe by applying the correct voltage to the power connections on the bottom of each airpod?
I do plan on getting placement charging cradle but its not possible for me at the moment.
Thanks.
Es esta una buena pregunta?
Puntuación 18
5 comentarios
Can this can be sought out, I lost my apple airpods charging case
- de
i have my airpds con i use my computer
- de
Hi can I use Airpod charging case gen 2 using airpod 1?
- de
.y airpod are fake so can it work still
- de
To login to the UPSers.com employee portal in 2023, follow these steps:
Go to the UPSers.com login page (<a href="#">https://upserscomlogin.online/</a>">https://www.upsers.com/</a>).
Enter your UPSers User ID and Password in the appropriate fields.
Click the "Log In" button.
If you are a new user and do not have a UPSers account, you can create one by clicking the "Sign Up" button on the login page and following the prompts to register.
- de
Agregar un comentario
6 Respuestas
Solución Elegida
Sadly, you need the case. The only option I could see here is visiting an Apple Store to see if they would be so kind to let you charge your ear pods. I would tell them you're visiting and left your case at home in some other land. This won't work to many times though ;-}
Sorry ;-{
Updated
Here’s a listing of cases now available Airpods Charger Replacement
Fue útil esta respuesta?
Puntuación 8
4 comentarios:
Thanks, i'll give that a shot :)
- de
Someone will come up with an alternate charging case for these gems. Mine got washed with the AirPods inside. They still worked, however the charger retained water inside the case as the only place for it to escape is through the charging points inside the AirPod holding spot. This charger seems to be only disassembled through destruction(cutting). A new charger is $79.99 USD… Someone come up with a cheaper alternative avoiding copyright laws and it’ll be a real money maker.
- de
For the second time I washed my Gortex jacket WITH my airpods-pro case in the pocket! Nearly cried. Now have the case buried in the middle of dry uncooked rice and we'll see how that goes. It didn't work very well last time and probably won't this time.
- de
@William Stratford - Forget it! Rice is great with Chicken its useless as a drier!
Here's more! Rice Is for Dinner, Not Repair
- de
I bought this and I love it: Stouchi Charge Dock for iPhone & AirPods (updated)
Puntuación 4
5 comentarios:
Can you use the AirPods Charger with some covers on the AirPods?
- de
Sadly the Qi charger logic requires the iPod case or a 3rd party case.
- de
- de
Find my is absolute bonkers I’d have a better chance of getting cancer and surviving than I would trying to find the case which mind you find my told me three separate time and gave me different locations like I spent 20 mins looking for my bs case now I’m going to have to spend another 100$ absolute fools how hard is it to track something?
- de
Might I reiterate just incase you are not physically inclined to handle such tasks find my is worthless and so is the apparent help center
- de
It’s probably a matter of locating the positive & negative locations on the pods, I have the same situation since last night, and the going to the Apple store is a good idea
Puntuación 0
6 comentarios:
Well I think i have the electrical equipment to see the voltage and current i just need to figure out how to stick the wires inside the port of the airpods case withouth making a short circuit and risking to damage my case and i might post it here
- de
I’m with you too dude, and need an answer to your exact question as well. There has to be a way to apply the correct voltage and amperage to the AirPods to produce the charging of the AirPods. Think we’ll need the right person who can think outside the box and have some electrical knowledge to respond though. Otherwise everyone is going to just say go to Apple instead of actually giving a good stab at what we’re asking here
- de
ill do it by myself you need a usb cable and powerbank just cut the usb cable and look for negative and positive use a powerbank because the powerbank stop charging if the battery is full its for not taking risk to destroy your airpods put the positive where the letter L/R was and negative in the other side
- de
Any updates to this question? I didn’t lose my charging case but am interested in the solution. I think one way is to 3D print some probes to go into the charging case, with wires coming out of the probe. There are two electrodes inside each of the “tunnels” where the AirPods go. Obviously, + and - electrodes. With wires coming out from the probes, you can then have connectivity to a multimeter(s). Then you can also connect these wires to the actual AirPods and check for voltage and current. However, I am not sure if the DMM loads (you’d need both a voltage DMM and one for series current) will affect the circuit because everything is so tiny. Even the wire thinness might add resistance to the whole shebang.
- de
There are quite a few 3rd party cases now. I would just get one vs trying to engineer my own.
- de
Mostrar 1 comentario más
I've had a pair of airpods for more over a year and have barely used them a handful of times.
Sadly, the airpods simply fall out of my ears. The problem was solved by using silicone covers for the airpods, however this created a new issue. With the covers on, I couldn't charge my airpods. It's a pain to put on and take off the covers. I have used this guide to find lost AirPods.
The charging of the airpods is done with two pins (the bottom silver parts, which are separated by plastic breaks). I was wondering whether there are any supports that can charge the airpods directly.
Puntuación 0
Try make something to charge your airpod you need a tiny magnet which will hold the earpod in place a phone battery connectors,which will work as connector to the earpod and a tiny bulb, a diode and a charging cable
Puntuación 0
Anybody know how to find the polarity of two charging contact of earbuds without charging case
Puntuación 0
Añadir tu respuesta
simon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 21
Ultimos 7 días: 101
Ultimos 30 días: 366
Todo El Tiempo: 257,847
