New 3DS XL power button light turns on and then turns off.
So, I just got done fixing my 3DS however it appears that It won't power on, it doesn't make any noise, or do anything, the power button goes on for a bit, and then just turns off, the only thing not connected are the speakers (broken ribbon cable connector)
Es esta una buena pregunta?
5 comentarios
you said you were done fixing it what did you fix?
- de ULEES
I fixed the shoulder buttons, however I also took out the motherboard and other things as I was going to replace the broken touchscreen however now I'm not sure. it's assembled at the moment.
- de RoastedHotdog
My cousin had the same issue after replacing the battery. The problem was corrected by blowing out all the cable connections and then replacing them.
- de M Perrick
"Blowing out all the cable connections" Elaborate please.
- de RoastedHotdog
The ribbon cable connector that is soldered to to speakers is what connects the motherboard to the top screen, so that may be your problem. Replace the broken cable.
- de Jaden
