Repair manuals and support for cars and trucks manufactured by Chevrolet.
Preguntas 870 Ver todo
Hissingnoise by brake pedal when applied
Hissing noise by brake pedal when applied, but little braking. Brake pressure good with motor off
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
@oldturkey03 is @jimfixer the iFixit’s mechanic?
por
Agregar un comentario
2 Respuestas
Solución Elegida
If you here a hissing sound it can be one of two things . First check the brake fluid reservoir. If the fluid level is down the his is probably the piston in the master cylinder has blown a seal . If the fluid level is fine then the hiss is probably from the power assist cylinder . Changing out the vacuum assist is easier than the master cylinder let us know what make and model your car is and year and we can provide instructional video for each job
Fue útil esta respuesta?
Calificación 3
Check your bearings. You may need to replace them.
Calificación 1
Añadir tu respuesta
Michael Spain estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 39
