Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
iPhone 6: Touch ID works but home button dosen't
Hey guys,
today I have an iPhone 6 where the home button doesn't work. Touch ID is fine. So I replaced the home button cable behind the LCD which didn't solve the problem.
Can anyone help me?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
i apologize, my previous response was for a different iphone.
most commonly, the home button flex itself is the failure. this is what would need to be replaced, which will cause issues with the touch ID, if not syncronized with the motherboard. This is done via a horizon machine, which is only available at apple certified repair centers.
There is also a possible failure in the home Extension flex, which you said you have replaced, so unless you got a bad part, then that is ruled out.
The other probilble failure is the motherboard, Be it a connector, or integrated circuit failure. changing the FPC on the board isnt too difficult, but anything past that would require extensive knowledge of the board.
Best of luck
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
This is the iPhone 6, are you sure you are not mistakening it for an iPhone 5s which would of had the home button connected to the charging port assembly via cable?
I think it's just a bad home button which would need to be replaced but touch ID will be lost.
- de
i am mistaking it yes. i will edit my answer to help, but yes, it is most commonly the button flex
- de
Añadir tu respuesta
elreparero estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 387
