Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 1517 Ver todo
Is cpu replacement possible
@refectio. so i removed u2000 and the processor from that 6s board, still getting shorts to the left of u2000. theres a few solder pads missing on the cpu and i was wondering can i replace it with a new cpu or is it the usual its paired with the board and i will have to try and repair cpu traces. the reason i removed cpu is because of the solder balls around it didnt look to good
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
The CPU is paired to the NAND, BB and EEPROM (and TouchID) so you can't just "replace" it. What do you mean by "getting shorts to the left of u2000"...which lines and on the left of what?
Fue útil esta respuesta?
Calificación 1
Comentarios:
seems to be buck1_lx0 . im not near it atm just looking at the schematic
por
If you can remove the 4 inductors on Buck1 (easier than removing the CPU) , then you will be able to determine if the short is on the PMIC side of things or the CPU side. If it's CPU, then it's pretty much dead.
Also, remember that PP_GPU is a low resistance line, it will probably only read ~10-20 Ohms so it looks like a short to the multimeter but its not really shorted. I just re-read your question and you already removed the CPU. What resistance are you reading on PP_GPU?
por
im getting open line
por
Añadir tu respuesta
daniel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 42
Últimos 30 Días: 158
Todo El Tiempo: 1,056
