Saltar al contenido principal
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
Preguntas 136 Ver todo
Samsung tab 4 7.0 won’t turn on after screen replacement
If I hold down power button for awhile, the backlight will come on and go off immediately and it will vibrate a little during this process
...but no logo or battery icon, even after leaving on charge for awhile.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @wizard870 ,
There's no easy way around it.
If you performed the screen replacement, you'll have to go back and check your work to verify that everything is how it should be. You wouldn't be the first to have overlooked something.
Here's a link to the ifixit Samsung Galaxy Tab 4 7.0 Screen Replacement guide that may be of some help.
If someone else performed the screen replacement, tell them of the problem with the tablet
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
@jayeff thanks for your reseponse. I unplugged the battery first as always, then the digitizer.
I normally don’t take the logic board out on my Samsung tab repairs bc I see it as an unnecessary step. Do you think this may have been an issue?
Thanks
- de
Hi @wizard870 ,
Hopefully the heat used on the digitizer panel did not get through to the logic board and affect it somehow.
Can you prove somehow that the replacement screen is OK or have you another one to try?
- de
I didn’t think about the heat. The replacement is okay. Do you think it could be the battery flex, seeing how it’s booting on then off? (Without any logo)
- de
Hi @wizard870 ,
It mightn't be the battery flex as something may be causing it to shutdown before it gets to showing anything.
Suggest that you disconnect the battery flex and then disconnect all the flex cables that you previously disconnected and clean their contacts with IPA 90%+ (Isopropyl Alcohol). Also clean the systemboard flex cable connectors (that you removed the flex cables from) with IPA 90%+ then ensure that they are all reconnected securely.
Just surmising that you may have inadvertently touched the bare connectors on a flex cable with your fingers and this may have made for a poor connection when the cable was re-inserted. After cleaning them with IPA (use a QTip moistened with IPA to wipe the bare cable contacts and systemboard contacts clean. Wait for it to dry also ensure that there are no fibres coming off the QTip) Then if possible either use gloves or do not handle the bare ends when reinserting the cable into the connector.
Can you get into recovery mode at all?
- de
No I am not able to get into recovery mode. Actually, I have to hold power button down for awhile for backlight to even show up. There are two spots on the LCD as well when back light does come on.
I will try alcohol treatment when I am back in the office.
- de
Añadir tu respuesta
The Wizard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,405
