Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 1857 Ver todo
iPhone 6s screen cable ribbon sparked/smoked
I replaced the screen on my iPhone 6s. After I attached the first ribbon cable to the phone, the second cable touched the pins and sparked and smoked for a second. I proceeded to finish, and the screen is now not turning on....What do I need to replace?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
UPDATE: The phone works, but just the display is not projecting an image. I can tell this because when I plug it in, it "dings", and the phone is vibrating.
por
You did not disconnect your battery before removing and installing the new display, the backlight fuse has blown, possibly the filter, diode, or IC damage.
It can still be repaired :)
por
You will need to test the backlight pins and check resistance to ground by using a multimeter, find out which pin has a damaged line, start from the top right and move to the left on the LCD Connector, there should be a solution on google, just type in 'iphone 6s backlight solution' it will show you the line to each pin. Check each component and see which part is damaged. It is not an easy do it yourself repair if you are not a microsoldering specialist.
por
Thank you so much. Any idea how much/how long these microsoldering repairs take, because I am not experienced.
por
Hey guys & gals! I have this issue too but mine never sparked. Also the screen has come fully back on for 1 - 2 seconds 2 times within a day of each other! I ordered a new screen but that hasn't worked. What fix do you recommend?
Thanks all!
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
2 Respuestas
Solución Elegida
You probably shorted out the backlight circuit. that's what the spark was. You have to disconnect the battery before disconnecting or reconnecting the screen assembly otherwise the backlight circuit has a tendency to blow. On the LCD connector, VCC_MAIN and GND are adjacent pins so if the connector is not perfectly lined up, it will short.
If your lucky, it's just a filter however sometimes the damage goes upstream and blows thew diode and or driver IC. This requires a micro-soldering repair.
To be certain, connect your phone to an iTunes enabled computer. Shine a bright flashlight on the screen and if you see a dim image, the the problem is the backlight circuit.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Whats a filter?
por
How do i know it is an issue with the screen?
por
The last paragraph of my answer will help you determine if the issue is with the screen or the backlight circuit. If the problem is with the backlight circuit, you will need to find a reputable shop that does micro-soldering repairs.
por
I see no image when I shine a flashlight. So the damage must have been done to the ribbon cable on the new screen? Is it possible that the spark damaged the circuit I was plugging the cable into?
por
Sure, it's possible. You have to eliminate variables. Try a new screen first and go from there.
por
Mostrar 1 comentario más
Clean the contacts and try replacing the screen again with a new screen.
Calificación 1
Comentarios:
por
You wont know until you either try some of the suggestions above from other people or get a screen from a reputable source that takes returns and if it is not the screen then you can send it back.
por
So if it isn't the screen, what should I do?
por
Then you can either look to to sending it off to have it micro soldered and repaired or you can look into a replacement phone or a replacement board.
por
Añadir tu respuesta
William Falb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 35
Últimos 30 Días: 182
Todo El Tiempo: 2,497
