iPhone 4 in bootloop and won't charge after screen replacement
Hey,
I recently replaced screen to my old iPhone 4. After reassembling I tried to boot it, but it just tries to boot all over again. Disassembled the device and checked all the connections, still not working. I replaced battery, home button and power button flex cable also, so they should work properly.
I tried with the old battery too, (I removed it as a working part) but it's not charging it. (the old battery was empty and it worked before I started the screen replacement procedure.)
Looks like the charging connector is broken(?) Also, my computer(PC) don't recognize the phone and neither the iTunes.
A little black component just below the righthand screw(which holds the protective shield for charging dock flex cable) have been cracked, can that cause this kind of problem?
Thanks for help!
Update (01/03/2018)
Thanks for help Minho, I uploaded a picture about the component.
I don't really understand the picture of the logic board's components, so I'm not sure which one of these it is.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
I guess that depends what "little black component" is damaged.
A picture here would help but if its Q2, most certainly that is the issue. If it's U5, then possibly but realistically, if you have damaged components that you can see with the naked eye, there is possibly more damage as well that would be seen under magnification.
Fue útil esta respuesta?
Calificación 2
Comentarios:
You circled U5. If it's damaged, then it needs to be replaced and the surrounding components need to be inspected.
por
Allright. Thank you very much!
Do you have any estimate how much the repair would cost?
por
Every shop charges differently depending on what part of the world you live in. Find a few micro-soldering repair shops near you or that offer mail-in repairs and ask them. Don't get too focussed on price though...look for quality and a solid reputation.
Realistically though, an iPhone 4 is not really worth investing a lot of money on and most shops will probably charge more than the phone is worth. Sad but true.
por
Yeah, that's what I'm afraid of, probably gonna give it to someone for free or just throw away, because after all I have iPhone 7+, which I use at the moment.
por
Añadir tu respuesta
erty estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 54
