Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
iPhone 6 wont charge after replacing battery
i replaced my iphone battery yesterday it came on with 75 percent so i ran it until it died last night. i placed it on the charger and saw the charging indicator and went to bed. i woke up this morning and its not showing anything, no charging indicator or anything just a black screen. i tried holding the power and home button for more than 30 seconds and got nothing. any ideas?
Es esta una buena pregunta?
Puntuación 1
4 comentarios
what was the reason for changing the battery, was the old 1 taking long to charge etc. if so it might not have been the battery but the charging ic. other than that it could the new battery is bad
- de
i changed the old battery because it was dying on 40 percent and draining very fast after short usage.
- de
could be the charging ic thats at fault
- de
It's charging ic if apple logo doesn't show with battery unplugged and charger plugged in.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
There are two possibilities here:
  1. You have a bad quality replacement battery
  2. You're charging circuit on the logic board is defective
Normally, the first step in troubleshooting is to replace the battery with a known-good (or high quality from a reputable vendor) battery.
You can also open up the phone and disconnect the battery. Measure the voltage of the battery with a multimeter. The phone requires that the battery be at least ~3.5V in order for it to boot. If you're battery reads higher than this, then you definitely have a logic board issue. Also try @benjamen50 suggestion.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
shaun estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 840
