It not powering up
The cord lights up when I plug it in but when I plug it into the laptop the light goes off on the cord and no lights come on on the laptop
Es esta una buena pregunta?
# Turn off the computer and remove the power cord.
# Remove two screws holding a panel on back in place.
# Next to the memory card you will see a switch which you need to turn to the OFF position
# Reboot your computer
Once the operating system boots correctly...
# Remove two screws holding a panel on the back cover.
# Next to the memory card you will see a switch which you need to turn to the ON position
The error has been cleared and your system should work properly.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 178
