Saltar al contenido principal
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
Preguntas 36 Ver todo
Green pixels on Chromebook screen when tilted at certain angles?
Every time I push back and pull forward my Chromebook screen, most of the previously black pixels turn green. It takes a lot of time to find the right angle where the image returns to normal. Is there a DIY way to fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
there is a black and green hole taking over my friends screen she is really scared so i need help fixing it
- de
@Logan Fortner, Best if you start a new question and post pictures of the problem you're seeing on the screen, that way we can help figure out what's going on with it.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Did someone recently service the device, or is this a refurbished device?
It sounds like either the display cables are getting pinched, or there is a loose connection. If you are comfortable doing so, I would suggest popping off the front cover of the lcd, and checking all the wiring, seeing if the problem remains if you loosen up the wires.
Fue útil esta respuesta?
Puntuación 2
I heard rumors that this is fixed by buying this game called CS:GO, you join into a community server called jailbreak, you type 123 in the console and then you pour milk all over your dog or cat or if you dont have any pets like that pour it over yourself.. (note : If you have a dog or cat and you decide to pour it on yourself it wont work) and then I think if im correct you watch the first season of death note and then its fixed.
Puntuación 0
1 comentario:
omg it worked!! tysm!!!!!!!
- de
Try re-connecting the video cable on the motherboard and at the back of the display.
NOTE:- You will need to take apart the machine to do this. But, at your own risk.
See “YouTube” videos for this, if you are unsure of the dismantling procedure.
If you do this, and it still plays up, then you need a new “video” cable… There are plenty to be had on eBay!
Hope this helps?
Puntuación 0
Añadir tu respuesta
Fel G estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,177
