Saltar al contenido principal
Modelo A1278 / 2.26 o 2.53 GHz Procesador Core 2 Duo EMC 2326 de mediados de 2009
Preguntas 745 Ver todo
Messed up colors on external display
When I connect my MBP through a minidisplay to vga adapter to my external vizio 26" monitor the colors become messed up. Black is green or blue and there is general static on the scree. How do I fix this?!?!
Es esta una buena pregunta?
Puntuación 2
3 comentarios
Can you provide the model number of the Vizio?
- de
corrected spelling on title of question.
- de
Well done David, as long as you didn't remove the u from colour
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Yesterday, I went to the apple store and bought a mini display to VGA adapter and now it works great. So, I think that it was the adapter but thanks for all the help I really appreciate it!
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
I find this happens when the plug isn't properly secured sometimes. But I am sure you have already tried that by now....
Try another monitor if you can and see if you get the same thing.
If you see this happening on other monitors, then you want to figure out if it's the adapter or the actual mini-display port on your computer.
If you have access to another VGA > mini DP adapter, then absolutely check to see if you can cancel out the adapter as the problem.
Component isolation is your first step. good luck!
Puntuación 2
2 comentarios:
yea thanks thats great advice I tried doing these things, but sadly I have a vga adapter and no other monitors take that input... thanks though!
- de
Glad it was the adapter!
- de
Try the moniter reset button/Degaussing? Wiggle connections?
Puntuación 0
Make sure your monitor's settings are set to RGB and not something like YPBPR.
Puntuación 0
Añadir tu respuesta
grey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 4,651
