Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1528 Ver todo
Screen Problem, vertical stripes
It was not reseting (error 4005), I replaced the battery and did reset without screen, and it worked. But when I plugged the screen back in, I got this strange issue. Note that the phone never hit the ground, it's in perfect conditions. I've tried to disconnect and reconnect all the cables, but nothing changes. Any clues ?
https://imgur.com/a/0VjPp
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
ABRIR TODAS LAS PESTAÑAS
Kits de actualización de RAM para Mac
Compra kits
Suficiente RAM
para todas las pestañas
Compra kits
2 Respuestas
Solución Elegida
Update ! I already had the cables properly connected. I just asked for help in a local store, they told me that should just be static electricity (?) stored in the screen. In 1 week it seems to have discharged itself, and now the screen I working perfectly. Hope this helps !
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Either the screen is not plugged in properly or the screen is damaged.
Unplug the battery and plug it back in and see if that helps.
Puntuación 2
Comentarios:
It's kinda strange here. This does not resolve the problem, but when I only connect the screen cable (so 1 connected and 3 disconnected), the screen shows the same, but with more pronounced lines. And now that's what happens when I plug it all back in : https://imgur.com/a/NAfmS
- de
the cable is not seated properly, try cleaning out the connection on the board and ensure the connector from the screen is flat (not bowed) before installing
- de
Añadir tu respuesta
Talerant estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 121
