Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 866 Ver todo
New charging port won't charge
I just replaced the charging port on an iPhone 7+ going step by step through the ifixit repair guide. The phone will not charge still.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
The original problem was that the charging port was worn out and chargers wouldn’t hardly charge unless hald just right. Once the repair was done, I plugged it in and the battery icon came up, I unplugged it and the image change telling me to insert the charger. An hour later it doesn’t even do that.
- Por
Agregar un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
1 Respuesta
Solución Elegida
It is possible you have a defective replacement part. Small parts, such as charge ports have high defect rates compared to replacement screens. Ideally you need to try a known-good replacement part.
However, if you're original problem was charging, then you may have a logic board issue, specifically the charge circuit. That requires a different skill-set to troubleshoot and repair. Consider having a micro-solderer look at your phone.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
- Por
Double check the connector to see if there is any damage. Beyond that, it sounds like a bad part. Have you tried the original flex to see if it works partially as before?
- Por
The original actually completely quit working hence why I went ahead and replaced it tonight. I double checked everything and all connections look fine.
- Por
Añadir tu respuesta
Erik Cordell estará eternamente agradecido.
Ver Estadísticas:
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 48
Todo El Tiempo: 1,277
