Surface Pro 4 screen replacement
So I recently purchase a SP4 bundle with a typecover and after a couple month of using i crack then screen, and decide to replace it, so i went on ebay and order a sp4 screen+digitalize model #1724, and process with the repair, and after i remove the crack screen and install the NTrig board to the new screen but the connector on the bottom doesnt match the flex cable. So i when online and check and i notice that my cracked screen looks alot like the new sp(5) screen model# 1796. Is it possible that a sp4 is using a sp(5) screen? also would it be cheaper if i just find a new flex cable for the model #1724, and is all the connect on the motherboard the same?
Es esta una buena pregunta?
1 comentario
Did you figure this out?
- de Quan Hoang
