Saltar al contenido principal
Apple anunció el Retina MacBook 2015, modelo A1534, el 9 de marzo de 2015 para su lanzamiento el 10 de abril. Tiene una nueva construcción Unibody e incluye un trackpad, teclado y pantalla Retina actualizados.
Preguntas 281 Ver todo
Replaced Retina display, but MacBook won't power up . . .
Recently replaced my early 2015 MacBook's retina display. Press the power button but nothing happens.
Have hooked it up to a 5 watt charger as indicated in one of the comments, but still no results.
Ideas on where to start on a trouble shoot?
Any ideas are welcome . . .
Will
Update (12/19/2017)
Okay! I think the display cable was loose. I reattached it and now it boots normally. Now, there is a milky haze around the border of the screen. Could this be the display cable, or should I get another retina display?
I have rebooted and adjusted display settings . . . External monitor looks fine , , ,
Es esta una buena pregunta?
Puntuación 1
7 comentarios
What happened to it that caused you to replace the display?
- de
LCD screen fell. Got cracked after falling. Still worked, but was like looking through a stained glass window. Now won’t power on at all with the new screen.
- de
ANYTHING happen? lights? sound?
- de
Just reopened the case. Last night, dead, no sound, nothing. Reconnected the charger and heard a single chime! At least it's something.
- de
It unscrewed the battery retaining screw and pressed the gold LED button , then reconnected the screw,
- de
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
It was a display cable connection. If your MacBook won’t respond, try reattaching the display cable.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Will Rast estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 210
